Author Topic: Oil filter video  (Read 4493 times)
Oil filter video
« on: January 03, 2019, 10:26:10 PM »
Recently posted on You Tube:
Re: Oil filter video
« Reply #1 on: January 04, 2019, 10:15:04 AM »
I get the feeling he's down on Fram.  Wonder how my AC filters stack up. probably best not to know yawl
« Reply #2 on: January 04, 2019, 11:22:16 AM »
You're definitely an empath.
https://tinyurl.com/RillRider
Offline stokester
« Reply #3 on: January 04, 2019, 02:37:10 PM »
Saw this on another forum as well.
No surprise here, Fram filters have been crap for years now.
I would like to see him do it with the OEMs; Motorcraft, AC Delco and Toyota come to mind.
  • Yorktown Virginia
« Reply #4 on: January 04, 2019, 02:51:25 PM »
In OZ you used to be able to get two different brands of Toyota filters. The commercial  Toyota's filters were vastly superior to the car ones which were locally manufactured. Unfortunately the commercial filters were not available for all the cars.
Offline stokester
« Reply #5 on: January 04, 2019, 03:53:08 PM »
I used the Toyota filters in my 4Runner, that is before a texting high school kid going to school hit it at speed totaling it out.  The Toyota ones always came with a crush washer.
  • Yorktown Virginia
« Reply #6 on: January 04, 2019, 04:55:48 PM »
We cut a couple apart to see how they differed. The commercial (Grey)ones were so much better in every way. Thicker base and body, better valve, thicker material and more of it. I believe the car ones (White) were possibly RYCO which I won't use on any of my vehicles. I only ever use Mahle or Mann on my Brick. The supply of  after market Mahle dried up in OZ so I have been using Mann. However as I am going to get some parts from Motobins I am going to order some Mahle ones.  Multiple orders offsets the freight costs a bit it actually should work out a little cheaper than the Mann ones.
« Reply #7 on: January 04, 2019, 05:15:06 PM »
After watching the video, I decided to see how the Carquest 85348 filter stacked up.  Turns out they are made by Wix, same as the Napa Gold.  Gives me a little more peace of mind.
A couple side notes: If you do use the Carquest filter(which is widely available and a few cents cheaper than the Wix) with synthetic, go for the more expensive of the two they carry.  The element is supposed to be specific for use with the longer oil change intervals that come with synthetic oil.
Back in the '80's I was a member of a Fluid Power Industry group.  Back then, servo hydraulics were the big thing for stuff like robots.  Servo valves were having lots of contamination problems, and the industry sponsored an engineering study of filter performance.  Literally hundreds of filters from almost every manufacturer were tested for efficiency and reliability.  The conclusion that I remember was that Fram was far and away the worst filter you could buy.  Because the Fram element shed fibers into the oil flowing through it, it was actually worse than no filter at all.
Offline stokester
« Reply #8 on: January 04, 2019, 06:47:50 PM »
I've always been a fan of Wix and the filters made by them until bought one for my daughter's Saturn Ion and found it was made in China.  I suspect the metal spin-on are USA but haven't verified it as I use Motorcraft on my truck.
My bricks get Bosch from BeemerBoneyard.
  • Yorktown Virginia
« Reply #9 on: January 04, 2019, 07:19:42 PM »
in Fram's defense, they have that nifty grippy surface and are bright orange so you can find them in funky unfamiliar engine compartments.
Offline alabrew
« Reply #10 on: January 05, 2019, 11:51:22 AM »
I recently went to NAPA to pick up a Mann filter for my car and the clerk repeatedly stated that WIX made the Mann filter, like I should buy that brand instead, but the Mann was on sale.
Here is one of many comparisons: http://www.austincc.edu/wkibbe/oilfilterstudy.htm that states that there are only 5 manufacturers of all the different brands.
  • Birmingham, Alabama
  • 1985 K100, 1991 K100RS
Also:
2005 K1200LT
1979 R65
« Reply #11 on: January 05, 2019, 12:14:38 PM »
My moto gets HiFlo 163 filters—made in Thailand, $10—$13, free shipping. I haven't seen one of those dissected yet. I'll put that project on my bucket list.
Offline Hilltopper46
« Reply #12 on: January 05, 2019, 11:00:51 PM »
There is truth in this statement, although one might argue whether the real number is greater or less than 5. However, the manufacturer builds the filter to the specs provided by the marketing company, so just because a filter is built by X, doesn't mean it has the same component quality as the filter provided under the X brand.
  • East Troy, WI
  • 1995 K1100LT
