OK, so I have gone back and has taken the rear brake to the tiniest bits, I could. Drained all the fluid, cleaned the reservoir, mc, piston, there are no banjo bolts on the tubes, but I have taken the connections apart and stared through the lines, cleaned, if necessary. Popped the caliper pistons with a bike pump and cleaned them again all around, bottom side and all. Also checked the bores, they are fine, but I have cleaned them as much as I could. Put everything back, bled the brakes and it is still dragging slightly. The rear rotor gets hot to the touch ridden the bike, warmer than the fronts. Fuel light came on today at 230 kilometers and I know from experience, tomorrow it will swallow around 16 litres of petrol, so fuel consumption is ultra-shite. I have never checked rotor temperatures before this issue, so I do not have a benchmark and I use my rear brakes quite a lot through city traffic, so that might be normal, who knows? Is there anything else I could try? I also measured the pads and rotor, pads are 3.88mm, rotor is at 4.2, so the PO was actually completely wrong about the rear worn beyond limit, actually it is all very good for now.... And yes, I have torqued everything down properly this time :D
Thanks!
