Author Topic: K75c wiring harness same for all years?  (Read 5482 times)
Offline Gr-Racing
« on: October 11, 2018, 08:45:28 AM »
Hi
My k75c  86 has some problems with the wiring burnt found a good replacement from a 1993 k75c, before i buy I figured i come here and ask.
As far as pic wise i can see that the combox plug are the same
My K is not abs would this be a problem with the newer harness
Thank you
  • GA
  • K75
Re: K75c wiring harness same for all years?
« Reply #1 on: October 11, 2018, 09:04:55 AM »
According to MAX BMW's parts fiche, K75C production ended in March of 1990, so something appears to be inaccurate in the part's representation by the seller. If the harness has ABS connections, those wires and connections will make the harness take up more space but it should still work to power the rest of the moto.
Plenty of members here have disabled ABS and will advise you shortly.
https://tinyurl.com/RillRider
Offline Gr-Racing
« Reply #2 on: October 11, 2018, 11:04:53 AM »
Thank you for the informed reply , i send the seller a msj to properly check the registretion hopefully he can send me a vin or something.
I have no problem with eliminating the are for abs just wanna make sure the harness will work for my late model k
Thanks
  • GA
  • K75
Offline Gr-Racing
« Reply #3 on: October 11, 2018, 01:05:19 PM »
Just received a message from the seller saying it was from the NON-ABS model.
Was it a option or a standard in 93
Thanks
  • GA
  • K75
« Reply #4 on: October 11, 2018, 05:45:47 PM »
Hi,
I believe that the ABS was standard on the K75S from 1990 onwards, so it would not have been an option.  Does the seller's harness have blue connectors?  If so, then it's an ABS harness.  No blue connectors and it's a non-ABS harness.  The ABS wiring will not interfere with the usefulness of the harness for replacing your existing burnt-out unit.
Offline CNRED
« Reply #5 on: October 11, 2018, 07:16:36 PM »
I just swapped a 1993 k75s wiring harness into a 1990 K75s.
Everything matched up perfectly.  Non-ABS to Non-ABS.
No issues.
  • Scottsdale, AZ
  • 1990 K75rt, 1992GSPD
Offline Gr-Racing
« Reply #6 on: October 11, 2018, 07:50:32 PM »
Thanks for the reply’s guys I went ahead an order it. Paid 50 bucks shipped and the harness includes all the relay’s so not bad
Thanks again
  • GA
  • K75
Offline Billk
« Reply #7 on: October 11, 2018, 08:55:26 PM »
Don’t end it here, let us know how you make out.
  • NYS
  • Owned many BMWs and Harley's presently '95 75K and '14 V Strom
Presently own a 1995 K75 and a 2014 Suzuki DL650
Offline Gr-Racing
« Reply #8 on: October 11, 2018, 09:15:08 PM »
Will do, should have install next weekend
  • GA
  • K75
Offline Gr-Racing
« Reply #9 on: October 15, 2018, 10:42:04 PM »
Got the harness looks great and newer than mine but i did notice the new 1993 harnes has the kick stand switch and my older 1986 doesn’t , is this going to be a problem
Any tips
  • GA
  • K75
« Reply #10 on: October 15, 2018, 11:10:44 PM »
The K75 didn't have a side stand switch regardless of its year of manufacture or model from what I've viewed on wiring diagrams and parts fiches. The '93 K1100 had a side stand switch. The '92 K100RS had a side stand switch. Is that switch labeled with a part number or other i.d.?
It's just a switch you won't be using.
Offline Gr-Racing
« Reply #11 on: October 15, 2018, 11:30:10 PM »
Thats what i thought also , but it has the 3 plugs for the injectors so is a 3 cylinder harness so that’s weird
I will check in the morning for a part number
  • GA
  • K75
Offline CNRED
« Reply #12 on: October 16, 2018, 07:29:17 AM »
Hummm...
I believe the fuel injector harness, the one that comes from the Jettronic box is separte from the main harness.  The main harness does not have the fuel injector connections. You may be looking at the coil connectors. there is also an accessory plug that lives in that area as well.  Could you be mistaking the accessory plug for a side stand switch connector?
  • Scottsdale, AZ
Offline Gr-Racing
« Reply #13 on: October 17, 2018, 03:30:26 PM »
  • GA
  • K75
« Reply #14 on: October 17, 2018, 03:54:20 PM »
Take a look here, Gr.
Offline Gr-Racing
« Reply #15 on: October 17, 2018, 05:16:08 PM »
Thanks im  feeling kinda dumb now
  • GA
  • K75
« Reply #16 on: October 17, 2018, 05:19:57 PM »
On the contrary—you should feel educated. :giggles
