Author Topic: Fitting a RnineT front wheel to a K75 1988  (Read 17831 times)
Offline Flodabo
Re: Fitting a RnineT front wheel to a K75 1988
« Reply #25 on: November 15, 2018, 03:20:21 PM »
You should perform a thorough tune up on your used moto that includes valve adjustment, throttle position sensor adjustment and throttle body balance
I’ve watched some videoclips about what you wrote. As I understand I should do all these 3 steps in the exact order you wrote them down. Is that correct?
  • Sweden, Gothenburg
  • k75s 1987
« Reply #26 on: November 15, 2018, 03:43:00 PM »
Valves and TPS must be done before throttle body balance.
Balancing the throttle bodies is the last thing you do.  It's done after any and all tune up operations like air filter, new spark plugs, injector cleaning, etc. are done.
« Reply #27 on: November 15, 2018, 10:08:53 PM »
You'll do the steps in any order I tell you to do them? Will you do other steps in between—like dance steps, tango maybe—if I tell to do them, too? What is wrong with doing what The Mighty Gryphon tells you to do? Do you think it's right he should feel left out? There are principles that govern how tuneups are done correctly. They are available from many sources.
I admire your resourcefulness in modifying your moto to the extent it is currently. Can you explain to me why you modified the moto first before you verified that its engine and engine operating systems weren't junk?
Offline Flodabo
« Reply #28 on: November 16, 2018, 01:37:41 PM »
Thank you!
I just got delivery from Motorworks with gaskets and more sweets.
I’ll be back for sure if I get into trouble:)
  • k75s 1987
Offline Flodabo
« Reply #29 on: November 16, 2018, 01:41:54 PM »
You can always rebuild a K engine. I heard :) or maybe because I know I can do anything if I put my mind to it. Yeah, must be that :)
  • k75s 1987
« Reply #30 on: November 16, 2018, 06:07:51 PM »
. . . or maybe because I know I can do anything if I put my mind to it. . . .
. . . or if you put other people's minds to it. :giggles  That's why we're here :yippee: , partly anyway, some of us.
Offline Flodabo
« Reply #31 on: November 16, 2018, 07:37:45 PM »
Wise as always:) beer time !
  • k75s 1987
Offline Flodabo
« Reply #32 on: November 17, 2018, 12:09:39 PM »
I really can’t blame it on that as I took the picture before I opened my beer 😂
  • k75s 1987
Offline Flodabo
« Reply #33 on: April 18, 2019, 11:31:18 AM »
So here is the main subject of this thread : a cnc machined bracket to make possible fitting the r9t front wheel.
* 6767AA26-746E-4519-98B4-DDCA58B157FA.jpeg (146.93 kB . 768x576 - viewed 624 times) I’m not sure if I should leave it like it is or painted black. Any thoughts?
  • k75s 1987
Offline Flodabo
« Reply #34 on: September 25, 2019, 02:05:03 PM »
* 12716B69-D8E4-4D15-87B1-1E5697108DED.jpeg (63.56 kB . 768x576 - viewed 570 times)
Here it is gentlemen. Isn’t she a beautiful lady? :) I want to thank you all for being so helpful and for your time during the last 12 months.  Bike has cleared inspection by Swedish authorities and is now read for DGR ride this weekend!
Thank you so so much!
Now it’s my time to share whatever knowledge I gathered with this build.
  • k75s 1987
Offline volador
  • NEEDS MORE CHROME
« Reply #35 on: September 25, 2019, 06:31:16 PM »
Congrats! Very nice work really like the front end/ fairing.
Good Riding
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
Offline Shonkster
« Reply #36 on: June 11, 2020, 08:59:18 AM »
Looks awesome Flodabo,
Any chance you could post details of the front axle.  Interested to know if you needed to change bearings, spacers etc and if you had part numbers for those.
Cheers
  • Melbourne Australia
  • SR500, K1100LT x 2
Offline Flodabo
« Reply #37 on: June 11, 2020, 09:11:05 AM »
Cheers
Hello Shonkster,
I used the K75 axel but had it machined a bit. R9t wheel came with bearings that fit spot on on K75 axel. Spacers from K75 cover the r9T wheel bearing almost perfect so I used those, again machined a bit.
Good luck with your build!
  • k75s 1987
« Reply #38 on: June 11, 2020, 11:06:09 AM »
Please verify if the tank was modified to straighten its lower profile and, if so, how that was accomplished.
Offline Flodabo
« Reply #39 on: June 11, 2020, 11:59:16 AM »
Hi Laitch
Tank is under a home made carbonfiber cover and in order to have that shape I had to move tank backwards a bit.
  • k75s 1987
« Reply #40 on: June 11, 2020, 02:02:26 PM »
Hi Laitch
Thanks for the clarification. Yours is a thoughtful customization and it can serve to show that fenders can be integrated into a compelling design; there is no particular need to be spewing water, mud and gravel in your wake, up your backside or into the works of the moto.
