Author Topic: RT to Naked Instrument re-location  (Read 2812 times)
Offline bluebossa
  • K75 and R65 Owner
« on: September 15, 2018, 09:25:46 AM »
On the basis that get and you should give, I thought this post might be useful to others.
Essentially while converting my RT to Naked I wanted to keep the Fuel and Temp gauges in operation - but where to put them?
Well searching on here I saw a custom K1 with something similar though hand made from Alloy, so set about emulating at low cost.
Searched eBay and found a Dual instrument pod - $5
Re-routed wiring to side of Engine
Mounted both instruments in Pod
Secured pod to Air Intake on lower front right of Bike - bit fiddly to get nut and bolts in, drilled a small hole.
Though the result is neither Art nor perfect, both gauges are in operation for very little cost and a couple of hours of messing.
Hope that help - great to have a fuel gauge and temp gauge in action. Also guess others could get an RT instrument setup from a Bike to retro fit onto Bikes without these, though you'd need the wiring and sensors too of course - especially the Fuel sender in Tank.
Result.
  • UK
  • K75 RT
Current Bikes: K75(RT) in the UK (06/91), R65
Former Bikes:  R850R, K1100RS, Dnepr MT10-36
BMW R65 and K75 Blog
Re: RT to Naked Instrument re-location
« Reply #1 on: September 15, 2018, 11:23:03 AM »
i gotts the same housing on my eleven hundert rs... i mounted them to the tragkorb so i could check them with a glance in the mirror... gotts my instrument cluster on the left tragkorb and the gauges on the right tragkorb...
has been 100% so far...
Offline bluebossa
  • K75 and R65 Owner
« Reply #2 on: September 16, 2018, 10:35:40 AM »
Any chance of a Picture or two, don't know where you mean dude.
  • UK
  • K75 RT
