hey,
Getting closer to the end of my K100 project.
I am installing a BEP3.0 but ....
The BEP 3.0 has several switches, i know the function of every switch but not the position they need to be in.
Does anyone have any idea what position the switches need to be in for choke, LED blinkers, fuel level and bulbtester.
for example disable choke, switch up or down??
Can't find any info about this.
thanks, M
Hi,
It might be your use the the word "switches" that is misleading. The BEP 3.0 is a sealed unit and there are no switches for the user to set or reset. There are strictly two connectors -- one to accept the OEM harness and the other to distribute functions to your bike.
- choke: It is the output pin labelled CHK
- LED blinkers: The output for the turn signal indicator on your gauge is labelled "<", ">" and "<>". However if you are asking where are the outputs for the actual signal lamps, there are none on the BEP 3.0. If you want to drive LED bulbs in your signal lights, you will have to make modifications to the flasher module.
- fuel level: If you have a K100 built between 1983 - 1985, then the low fuel indicator output on the BEP is labelled "BAR". If you have a K100 built after 1985, then there is no fuel level output signal from the BEP. You have to wire that up yourself.
- bulb tester: It is the output labelled "BT"
