Author Topic: FS: Various parts from silver 1990 K75S  (Read 5914 times)
Offline oneplustwo
« on: July 07, 2018, 12:41:45 AM »
Hi folks - Not sure if any of this stuff is worth anything but I figured I would give it a shot.  All prices negotiable.  Pick up in or around San Francisco.  Actual shipping added once deal settled.
Instrument cluster - $200
Hard bags - $140 for both (both sides could use a new hinge piece.  Have one key.)
Hard bag rack/brackets - $50 for both
Saddle - $100 No tears or rips or holes
Headlight, turn signal shroud - $50
Rear tail section - cracked and faded - free
Other miscellaneous stuff - make me an offer
  • San Francisco
  • 1990 K75S (in 1000 pieces)
Offline oneplustwo
Re: FS: Various parts from silver 1990 K75S
« Reply #1 on: July 07, 2018, 12:43:07 AM »
more pics
  • San Francisco
« Reply #2 on: July 07, 2018, 10:33:34 AM »
Just a suggestion to help everybody out.  You are selling a low seat.  Most people looking for one want to replace the regular seat they already have.  The low seat requires a bunch of extra hardware that isn't on the bike with the regular seat.  You might want to make a package of all the parts that go with it, especially those two hooks on the tail cowl.  Some of those parts are no longer available and the seat won't work without them.
Offline oneplustwo
« Reply #3 on: July 07, 2018, 11:35:31 AM »
Thanks for the perspective. I had no idea. In any case, I’ll do what you said. Just need to assemble the bits together. Pictures to follow.
  • San Francisco
Offline oatmeal
« Reply #4 on: July 07, 2018, 12:28:06 PM »
Pm'd on the cases
  • Indy
  • 09/1991 K75s
Offline CNRED
« Reply #5 on: July 08, 2018, 08:35:57 AM »
PM sent on headlight turnsignal shroud.
  • Scottsdale, AZ
  • 1990 K75rt, 1992GSPD
« Reply #6 on: July 08, 2018, 08:41:49 AM »
Use the exploded diagrams on RealOEM to guide you in identifying the parts related to the low seat.
https://www.realoem.com/bmw/enUS/showparts?id=0574-USA---K569-BMW-K%2075%20C%20(0564,0574)&diagId=52_3686
Offline oneplustwo
« Reply #7 on: July 09, 2018, 12:28:40 AM »
Headlight shroud sold.  Saddle bags have interest.
  • San Francisco
Offline Zampano
« Reply #8 on: July 09, 2018, 12:36:07 AM »
Hi,
Any chance you have the coolant reservoir?  Mine decided to crack (the little see through level part) and spray hot coolant in many directions.
I'm also in search of front and rear master cylinders (however I might be able to rebuild those) and possibly a good quality shock.
Thanks.
James
'92 K75S
Offline oneplustwo
« Reply #9 on: July 09, 2018, 01:48:59 AM »
I think I do have the coolant reservoir.  Front master cylinder too (and both left and right control assemblies actually.)  I'm going to reuse the rear master cylinder.  And I'm keeping the Ohlins shock that came with it so can't help you there.
PM me for what you think a fair offer is for the reservoir and the front master cylinder.  I'll probably just send you the whole right side assembly.
Hi,
Thanks.
James
  • San Francisco
Offline Jethroww
« Reply #10 on: July 12, 2018, 12:52:32 PM »
PM sent on rear tail section
 Thanks
  • Ontario,Canada
  • BMW 1974 R75/6, BMW 1988 K75s Past: 1972 Norton Commando Combat
Offline cavis86
« Reply #11 on: July 20, 2018, 11:07:51 AM »
PM'd for handlebar cover etc.
  • Washington, DC
  • K75S
Offline MadEyeGuy
« Reply #12 on: July 23, 2018, 06:24:40 PM »
If you have ALL the parts for the seat and it is in good condition I would be interested. Like was mentioned, you can't find the parts no matter what the condition the seat is in.
  • Colorado
  • 1991 K75 Standard
Offline SKY75
« Reply #13 on: July 28, 2018, 01:43:54 AM »
Do you still have the rubber ignition/switch pad?
  • Garage
  • K75
Offline earlguy
« Reply #14 on: August 15, 2018, 09:13:34 AM »
Did you find the parts for the low seat? Very interested. Thanks!
  • North Woodstock, NH
  • 1990 K75S
Offline oneplustwo
« Reply #15 on: August 15, 2018, 01:37:28 PM »
Sorry, I took a first look but didn't find them but I'm sure they're around somewhere.  I'll take another look and get back with photos.
  • San Francisco
Offline Motorhobo
  • +20 years of K75
« Reply #16 on: August 16, 2018, 06:37:23 AM »
Hi,
Thanks.
James
Be careful on the reservoir. I got one off eBay once that had the outlet port coming off the wrong side and it was useless. I ended up springing for a new one because that part tends to corrode so bad around the sight glass, which isn't glass but some translucent abs crap.
1994/1995 K75 ABS Frankenbike: original engine 136k miles, frame from Gary Weaver (RIP), 173k miles -- Current Odometer: 193k miles
1994 K75 since 2013, 76,000 mi (11k mine) w/California Sidecar Friendship II Sidecar & Black Lab 'Miss B'
Offline thestza
« Reply #17 on: August 16, 2018, 02:36:08 PM »
hey mang. are you selling your keyed ignition switch by any chance?
  • gross angeles
  • 1988 k75$
