Author Topic: Engine ~ Air ~ Fuel ~ Spark ~ Cooling ~ Exhaust  (Read 4483 times)
« on: March 31, 2018, 07:07:56 PM »
VALVES
Kenneth Lively Polepenhollow Valve Tools and Clutch Pilots
Checking Valve Clearance on a K1100LT
Checking/Adjusting Valves on a K75/K100
K75 K100 Valve Adjustment Tools Videos
Classic K Valve Adjustment Tools
Valve Adjusting Tools for K75 & 2V K100 models (clutch pilot for all Ks)
K75 K100 K1 K1100 Valve Adjustment Seminar
SPARKPLUGS ~ PLUG WIRES ~ COILS
K75 Firing Order
K75 Coil Plug Wire Layout
NGK BOSCH Spark Plugs
Running newer style K100 ignition coils on an older K100 (video)
SPRAG CLUTCH
DIY Sprag Sprague Clutch Easy Fix
Getting the bellhousing off/accessing the starter sprag
THROTTLE BODIES ~ INJECTORS
Removing/Installing K75/K1002V Fuel Injectors
Fuel Injectors
My K runs like crap at idle but does OK at higher RPMS
Getting Fuel Injectors Reconditioned
4 Valve K Bike Intake Manifold Rehab
Synching K Bike Throttle Bodies (applies to all K bikes)
DIY Throttle body synch
Adjusting the TPS (Throttle Position Sensor) on a 4V K bike
Adjusting the TPS (Throttle Position Sensor) on a 2V K bike
STARTER ~ ALTERNATOR
K Bike Starter Info
CAM CHAIN ~ TIMING CHAIN ~ HALL EFFECT SENSOR ~ SETTING TIMING
Bike Just Quits Once The Engine Warms Up (Flaky HES)
Hall Effect Sensor Test
Advancing the timing on a K75 or 2V K100
DIY Can Chain Tensioner Depresser (for 4V K bikes)
Timing Chain Rattle Diagnosis
K100 Timing
K75 Timing
COOLING SYSTEM
Alternative Fan by wmax351
Cooling Fan Activation Time Interval by rbm
Cooling System Operation for K Bikes
Fan System Diagnostics for Two Valve K Bikes
Water Temp Sensor Ohms for 94+ bikes
Manual Fan Switch Mod
Alternative Thermostat
Some water temp sensor data points (93- 4 valve K bikes)
AIR FILTER
Replacing/inspecting the air filter on a K bike
K Bike Air Filter
OIL AND  FILTER
Alternative Oil Filters by wmax351
SEALS
DIY Tool for Seating Rear Main Seal
Oxygen Sensor Testing
FUEL TANK ~ FUEL PUMP ~ FUEL LINES ~ FUEL PRESSURE REGULATOR
K75 K100 Fuel Tanks
Alternative Fuel Filters
Air Accumulator (a.k.a. "The Cup")
Replacing the fuel lines on a K1100RS
Aftermarket Fuel Pump01
Aftermarket Fuel Pump02]
Replace Fuel Level Sender Connector
Aftermarket Fuel Pump by f14crazy
EVERYTHING ELSE
Oil Filters for Motobricks
How to add an altitude switch (US K75s and 2V K100s)
Rough Idle When Cooling Fan Runs
Intermittent Engine Cutout Problem Solving
