Bad news. As RBM suggested, I executed a a process of elimination to determine the route cause of the lack of back light in the speedo. It was a short process. I ran B-Backlight+ Purple directly to the battery and with the ignition on, the backlight illuminated, returned it to the BEP respective output and lost backlight. The problem is in the BEP 3.0 unfortunately. I’ve contacted cafe4racer, where I bought it and provided them with a short video. Thanks for your direction here, Robert.
On a brighter note, I completed the BMU “gutting”. I see why they call it gutting, it is a savage mod. The same could be achieved jumping directly into the plug with spade terminals and cable but doing it within the original housing does give you the luxury of keeping the original cover.
That concludes the major wiring of the build, everything is functioning as it should, with the exception of the BEP fault and I’ve yet to prove the repair of the fuel sender harness.
Tomorrow I’ll hopefully get the fuel pump reinstalled in the tank with new submersible hose and filter. I’ve got a gas can in the car to get a squirt of fuel on the way home.
