Hey!
I like your posts on instagram, you are really going fast!
I opened mine switch, because i knew there is some problems! Mine gear possition indicator on the dashboard is damaged so i cant see any gear, but it only showed something different when i was in third and fifth gear. That is why i opened it.
I opened it and found out, that one of pin springs is melted (idk why). I changed spring with bmw e46 door lock spring! It was quite longer, but it worked!
About testing- you can use multimeter with beeping function. Take diagram with colours from that forum posted before. Put it in some gear, or if it is taken off, do a manual turn with screw driver. Put it in some “gear” and test it.
Im not a tech guru, so i improvised! Switch works now, but it dont show neutral light.. i took dash board from friends k100 and green light worked, so the problem is in my dash board (but have no clue where..)
