Author Topic: "Revive" (1985 K100 Street Scrambler Build, not a Cafe Racer)  (Read 70717 times)
Offline volador
  • NEEDS MORE CHROME
Re: "Revive" (1985 K100 Street Scrambler Build, not a Cafe Racer)
« Reply #500 on: May 14, 2020, 06:17:49 PM »
'Pin #85 of FI relay should see -12v: It reads nothing. However when red lead is on battery positive and black to pin #85 it reads 12v when the start button is depressed.'
'correct ground test' is verified- you have established ICU Pin7 is providing ground for Pin85 when starter button is depressed
Pin #30 of FI relay should see +12v at any time even with ignition off: It reads nothing.
you need to check wire to FI relay Pin30 as you said should see +12V  -maybe sparky sparky no likey
you can jumper Starter relay Pin30  to FI relay Pin30 for +12V for test starting
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
Offline DJEwen
« Reply #501 on: May 31, 2020, 06:17:41 AM »
Ok- I checked the connections in the fuel injection relay socket and all seems well, no issues. The replacement relay arrived and I installed it but I still have no fuel pump. Itís also fantastic weather outside :(
  • Scotland
  • Redline 7000
  • Forum Moderator
« Reply #502 on: May 31, 2020, 08:09:26 AM »
Have you removed the fuel pump and checked it for operation on the bench. The battery problem and the fuel pump problem could be coincidental.
  • 1995 K75 77,000 miles
https://tinyurl.com/RillRider
Offline DJEwen
« Reply #503 on: May 31, 2020, 08:46:58 AM »
I have, Laitch. Itís working fine.
Iíve had some mice recently, caught a load. Iím wondering if maybe something has been chewed.
  • Scotland
  • Redline 7000
  • Forum Moderator
« Reply #504 on: May 31, 2020, 08:51:55 AM »
Is there continuity at your recently cleaned four-pin plug and at the connection between the fuel gauge and the pump?
Offline DJEwen
« Reply #505 on: June 01, 2020, 08:43:00 AM »
There is continuity at the four pin. Are you suggesting testing for continuity inside the tank from the 4 pin to the pump? I hadn't done that.
I remember back at Post #239 on page 10 then RBMs reply at #242 he suggests dodgy internals of the old type senders but he may be referring to the thermistors to the fuel level gauge.
  • Scotland
  • Redline 7000
  • Forum Moderator
« Reply #506 on: June 01, 2020, 11:32:34 AM »
That's what I'm suggesting.  icon_cheers
Offline DJEwen
« Reply #507 on: July 25, 2020, 02:26:08 PM »
Iíve still not got the K started, neither have I got the garage built. To satisfy my throttle therapy in the meantime, I picked up a used 2018 R NineT Pure Sport with 1300miles on the clock. Itís an effortless machine to ride.
  • Scotland
  • Redline 7000
  • Forum Moderator
« Reply #508 on: July 25, 2020, 09:46:09 PM »
That looks fun! Does Pure Sport translate from German as Send your luggage ahead:laughing4-giggles:
« Reply #509 on: July 26, 2020, 12:59:23 AM »
No Laitch it translates to I wish I had a padded seat or a more ample bum. One of the OZ Kluster Krew has one.
Offline DJEwen
« Reply #510 on: July 26, 2020, 05:16:21 AM »
Meh, I managed with the K!
Luckily, it has the upgraded seat, and twin gauges from the racer so I have GPI, rev counter fuel gauge :D
  • Scotland
  • Redline 7000
  • Forum Moderator
« Reply #511 on: July 26, 2020, 09:25:06 AM »
It's an attractive design. I found a tutor if you want to test its limits. I'd give it a try if one came my way.  112350
