Author Topic: Old brick restoration  (Read 2358 times)
Offline Lucky_Ted
  • Mechanical Novice
« on: November 27, 2017, 08:29:19 PM »
Hello everyone, first time posting here:
What I got is my old man's k75c and it has been sitting for about 8 years. It was retired due to "shifting problems". I've already ripped into the clutch and found that it needs an engine seal, a friction plate, and a rubber boot for the clutch arm. Also some debris fell from the garage and smashed the speedo. The bike has yet to be started, would starting it with a broken speedo cause any problems with any sensors or electronic brains in it? Clutch parts will get replaced as soon as I get parts in and an aftermarket speedo is next on the list, but in the meantime I was wondering if there were any other spots I should check with something that's been sitting so long. Are there certain seals that could dry rot that need checking or are there any considerations I should make before starting it up? Any help is greatly appreciated, this is my first time touching a bike and I'm not sure what I'm looking at.
  • Michigan
  • Broken down 87 k75c
Online The Mighty Gryphon
Re: Old brick restoration
« Reply #1 on: November 27, 2017, 08:52:50 PM »
There are lots of threads here about starting up old K bikes.  Biggest problems seem to be related to old fuel sitting in the tank and injectors.  It forms gum that clogs the injestors and the ethanol dissolves the rubber stuff in the tank.  Second majot trouble area is the plethora of electrical connections that get dirty over years of storage.  You may have to go through and do a wholesale cleaning of electrical connections with a can of DeOxit spray.
Last, when you say shifting problems, first thing that comes to my mind is a grub screw in the transmission that holds the shifter linkage to the shifter shaft.  How much slop is in the shifter?  If there is a lot of slop you will have a lot of missed shifts, both up and down.
More than a quarter inch indicates that the screw is loose and needs to be tightened.  This is a job that requires opening the transmission.  Took me a couple hours when I first got my K75RT to tighten the screw.  If you do it along with clutch work, you save the time to pull the transmission since it's already off.
  • '94 K75RT Mystic Red, '92K100RS White, '94 K75S Dakar Yellow
'94 K75S "Cheetos"
'91 K100RS "Moby Brick Too
« Reply #2 on: November 27, 2017, 11:07:56 PM »
+1 on not trying to start it before cleaning out the gas tank.  Also the rubber surround on the fuel pump tends to disintegrate in old gas, creating a multitude of problems.   A description as nebulous as "shifting problems" leaves the door wide open to speculation.  Clutch, grub screw, and with some 86-87's they used a shift drum that was not hardened properly, causing bent shift forks and jumping out of gear.  Usually it's cheaper to find a used transmission rather than tearing into a bad one and replacing parts.
2012 Ural 2WD sidecar (BMW's bastard step child)
Offline TaosBrick
  • RedHotMotoBricker
« Reply #3 on: November 28, 2017, 09:23:37 AM »
Chaos basically covers everything, save that it's ok to start it with the busted speedo (once you deal with fuel system) Speedo keys off a sensor on the final drive.
- Samurai Maxim
Offline Lucky_Ted
  • Mechanical Novice
« Reply #4 on: November 28, 2017, 10:14:10 AM »
Thanks for the help guys. I admit "shifting problems" is highly nondescript. The best description I could get from the old man was that he had to nearly kick the clutch lever to get it back home on it's last ride. It got a new clutch cable before I got to it, and the "cup" boot on the clutch arm has been completely ripped up. I didn't think anything about the tranny itself, so getting a look at it before it goes back definitely helps. Again, thanks for the advice everyone!
  • Michigan
« Reply #5 on: November 28, 2017, 11:14:55 AM »
"Kick the clutch lever"?  Sounds like a clutch problem.  Bad cable, or possibly the clutch arm on the back of the transmission is seized(a not uncommon problem).  Some of the inmates have installed grease fittings on that arm to allow it to be lubed from time to time.  Could also be a very badly adjusted clutch cable.
The boot is a fragile, expensive part that suffers when the clutch arm is allowed to drop with the cable disconnected.  To protect the new boot always support the arm when the cable is disconnected.  All it takes is a bit of string to tie it in the up position.
'94 K75S "Cheetos"
« Reply #6 on: November 28, 2017, 11:44:33 AM »
He must have had an interesting riding technique, I have a hard time getting my foot up that high.
Offline Lucky_Ted
  • Mechanical Novice
« Reply #7 on: December 04, 2017, 09:31:19 PM »
Update: getting all the parts I need for the clutch tomorrow. While I'm this far up the bikes business end is there anything on/in the engine that usually needs to be checked? The general consensus seems to be to leave the motor alone, but there's got to be SOMETHING to check before putting half of it back together, right? I've looked around the site but most I could find was the engine rebuild videos. Should I just wait until the startup for any funk to happen and troubleshoot from there? :dunno2:
  • Michigan
« Reply #8 on: December 04, 2017, 10:32:14 PM »
Fitting grease nipple to the clutch pivot arm will save you a lot of headaches. The occasional application of grease pushes out any crap. And it stops crap and water ingress. Easy job but the arm needs to be removed, normally drilled and tapped to accept a 6mm grease nipple.
« Reply #9 on: December 04, 2017, 10:37:51 PM »
I'm not sure you posted how many miles your dad put on the bike, but you should bear in mind that these bikes take at least 20,000 miles to get broken in.  As long as the oil is changed, and the valve clearances checked the mechanical workings should be good for well over 150,000 miles.  Remember that you are essentially dealing with a car engine here.
Change the o-ring on the output shaft and do a clean and lube on the clutch splines.
Check the air filter for mouse nests, throw in some new spark plugs, and balance the throttle bodies.  Run a couple tanks with Techron through the injectors.  Check all the rubber bits for holes and cracks.  Beyond that there isn't much the engine needs if it's got less than 100,000 miles on it.
About the transmission.  If the grub screw is loose this is a really good time to address it.  Does the shifter flop around freely?  If so, how much?  My RT had shifting problems because that screw was loose.  You don't want to go into the transmission after the bike is put back together.
Have you done or made plans to do all the maintenance, brake bleeds, fork oil, cooling system, etc.
'94 K75S "Cheetos"
« Reply #10 on: December 05, 2017, 06:46:48 AM »
Rebuilding a K-bike engine is an uncommon need. You should look into the Repair Guidance section under the categories General Maintenance and Operation. As indicated previously in this thread, the fuel tank should be inspected and cleaned if necessary. Remove the filler cap assembly by removing the four screws in its flange then syphon out the fuel. That will allow a good look. Don't run any old fuel through it.
  • 1995 K75T 68,000 miles
Offline Lucky_Ted
  • Mechanical Novice
« Reply #11 on: December 05, 2017, 08:47:18 PM »
I think the bike is just under 50k, but it could be a little different, given that the speedo is pretty busted up (aftermarket speedo is on the shopping list).
In terms of the tranny, I think the grub screw may be fine? Is the shifter the foot lever that switches gears? If so, it doesn't move freely. When pushed down, the shifter makes an audible click, and pushing it up resets it (I'm assuming this is supposed to be shifting in/out of gear and totally normal?)
As for general maintenance post repair, I'm definitely replacing fluids, brakes, filters, etc along with all the suggestions you've made. I'm glad to hear that the fuel system will be my biggest worry. Also, good luck with Moby Brick, your winter project looks more in depth than mine.
  • Michigan
« Reply #12 on: December 05, 2017, 11:18:45 PM »
Yes, the shifter is that thingy in front of the left footpeg.  You should feel spring resistance to any attempt to move it up or down from it's center position.  If it flops freely, the grub screw is loose.  On my bike the damn thing flopped at least an inch and a half before I could feel the spring.
'94 K75S "Cheetos"
Offline Lucky_Ted
  • Mechanical Novice
« Reply #13 on: January 01, 2018, 07:19:47 PM »
Happy new year, everyone!
It's been a minute and i haven't had much time to finish things up. But now I've got some new parts and spare time to get back at it. I got a main engine seal from my local dealership, and I know that the newer seals are different. Just double checking if this is the right one. The part number is 23121451020, which is different than 23121451151 that I've seen on other threads. [/size]Is it supposed to be that small or did i get the wrong one?Also, I've got some good news. After siphoning out the gas tank, I've found that it's in far better condition than expected. It looks like everything inside the tank is intact. The only concern here is that one small hose has cracked off. I didn't see where it was attached but I have a feeling it goes to the "nipple" just under the filler opening. I attached some photos of the inside of the tank and the hose that fell out if anyone has a better idea of what the hose is (part #?).
  • Michigan
Offline Lucky_Ted
  • Mechanical Novice
« Reply #14 on: January 01, 2018, 07:29:00 PM »
It's been a minute and i haven't had much time to finish things up. But now I've got some new parts and spare time to get back at it. I got a main engine seal from my local dealership, and I know that the newer seals are different. Just double checking if this is the right one. The part number is 23121451020, which is different than 23121451151 that I've seen on other threads. Is it supposed to be that small or did i get the wrong one?Also, I've got some good news. After siphoning out the gas tank, I've found that it's in far better condition than expected. It looks like everything inside the tank is intact. The only concern here is that one small hose has cracked off. I didn't see where it was attached but I have a feeling it goes to the "nipple" just under the filler opening. I attached some photos of the inside of the tank and the hose that fell out if anyone has a better idea of what the hose is (part #?).
Don't know what happened there, here's the text from that post made legible:
  • Michigan
« Reply #15 on: January 01, 2018, 11:07:49 PM »
It probably is a remnant of the hose connecting the pump strainer basket to outside venting. See a photo at this link.
« Reply #16 on: January 02, 2018, 09:09:55 AM »
The forum software mangles text when you try to paste it into the editor window on the site.  The software adds seemingly random tags to the text that reduces its size to 2 points.  Very frustrating!  You need to edit the post and eliminate the tags that were added.
I can't comment on the seal or its size difference.
The hose is the one that connects the fuel pump filter basket to the fuel return just below the gas cap in your photo.  Laitch pointed you to a link but his post also got mangled.  This is the link:
http://www.k100-forum.com/t5568-photos-from-inside-the-fuel-tank#121586
That special hose can be bought from BMW.  It needs to be immerible so regular rubber hosing will not work.  It can also be safely eliminated with no adverse effects.
« Reply #17 on: January 02, 2018, 10:45:36 AM »
I think your computer and software are doing the mangling, Robert. The post and its link are intact when I access them from my Mac and also from a Windows PC system. Maybe it isn't cold enough where you are yet. :giggles
Offline bocutter Ed
« Reply #18 on: January 02, 2018, 12:02:21 PM »
[Xsize=2px]It probably is a remnant of the hose connecting the pump strainer basket to outside venting. See a photo at this link.
[/size]
Well, it does start off with the size=2px command  :hehehe
  • Toronto, Canada
« Reply #19 on: January 02, 2018, 05:54:25 PM »
That's right Ed.  The Motobrick editor will inject its own markup tags around text you copy/paste.  My Mac does this all the time; I don't have a PC with Windows to experiment with.  I have to edit my post and go into RAW mode to delete the injected tags.  There can sometimes be dozens of them and it takes a while to clean up the mess.
« Reply #20 on: January 02, 2018, 07:35:22 PM »
It doesn't show that corruption on my computer screen, Ed, so I can live with it. :giggles I have the site's WYSIWYG editor activated. Robert's problem didn't show either. I think it's just Microsoft messing with you.
Offline bocutter Ed
« Reply #21 on: January 03, 2018, 12:51:16 PM »
Don't think so. Une 27" iMac at home. Shop has a 20" iMac, a dual monitor G4, and an old hopped up 9600 for the scuzzy scanner ...
  • Toronto, Canada
