Author Topic: The MechaniK  (Read 8274 times)
Offline Gabi Nicolae
The MechaniK
« on: November 04, 2017, 03:25:43 AM »
Hi guys, we just started a project precisely one month ago. The results look good, so I thought maybe it is helpful for the community to see it. Usually we are building racing cars and customs, not bikes. Best regards and I hope to have time to keep you posted.
Sent from my SAMSUNG-SM-G891A using Tapatalk
  • Romania, Europe
  • Ktm 1190 Adv, Ktm 640 Adv, BMW k100 Taifun
Re: The MechaniK
« Reply #1 on: November 04, 2017, 03:29:24 AM »
And this is the status as of today. Nop, the muffler is not this one, I just wanted to check the proportion :)
  • Romania, Europe
Offline Andrew2
Re: The MechaniK
« Reply #2 on: November 04, 2017, 05:23:49 AM »
  Awesome work mate. Some really interesting stuff there. Keep us posted  :2thumbup: .
  Cheers
  Andrew
  • Wollongong, Australia
  • 1987 K100RS
It is no measure of one's health to be well adjusted to a profoundly sick society
Re: The MechaniK
« Reply #3 on: November 04, 2017, 05:40:00 AM »
  Cheers
  Andrew
Thanks Andrew :) Actually I have  few ideas, never implemented on a bike . I ll keep sending pictures of the fabrication process.
  • Romania, Europe
Re: The MechaniK
« Reply #4 on: November 04, 2017, 05:49:40 AM »
Anyone knows how to upload a video file please? Thks
  • Romania, Europe
Re: The MechaniK
« Reply #5 on: November 04, 2017, 06:30:56 AM »
Welcome, Gabi Nicolae! Work presented with high quality images like yours is helpful.
If it is a YouTube or other video with a URL, just paste its URL in the reply box. If it is a personal video file, you can start an image and video gallery here by following these instructions.
  • 1995 K75T 68,000 miles
Re: The MechaniK
« Reply #6 on: November 04, 2017, 06:41:02 AM »
Ok, thank you very much
  • Romania, Europe
Offline Dutton
Re: The MechaniK
« Reply #7 on: November 04, 2017, 08:21:44 AM »
Wow nice vision looks great! Looking forward to seeing more
Cheers
Dutton
  • Alberta - Canada
  • 1985 K100 LT
Offline Arktasian
Re: The MechaniK
« Reply #8 on: November 05, 2017, 09:59:24 AM »
Another Turbo :clap:
Tight quarters on the tranny for it, will you be adding an air to air cooler?
Any plans for fuel management?
Re: The MechaniK
« Reply #9 on: November 05, 2017, 10:14:23 AM »
My intention is to run a low pressure, like 0.4-0.6 max. The debitmetre of the bike should do the job of sending more fuel. If not, we can write a new chart on the ECU.
Regarding the intercooler : it is not a must, but yes, would be helpful. But to do not forget the fact that earlier turbo engines didn't have an intercooler at all. Maybe I could install an air /water intercooler, using the engine refrigerant. We will see :)
The idea of the turbo setup is not about the extra power, but about the specific noise of the BOV :) So, that's why I don't want more turbo pressure.
  • Romania, Europe
Offline Arktasian
Re: The MechaniK
« Reply #10 on: November 05, 2017, 11:09:23 AM »
Low boost, you might refer to it as "Normalizing". Not much heat compressed into the air charge at those levels so yes, a cooler not important - in fact might hinder performance.
However, if it's the thrills and chills of a noisy, squawking BOV, then depending on valve chosen and turbo flow, you may not have enough blow off to make the noise. I find the sounds are cool but you can only roll on and off hard so many times when your bike is a daily rider. For "Show" - guess that's another matter.
Offline AtLarge
Re: The MechaniK
« Reply #11 on: November 05, 2017, 06:10:13 PM »
You guys do good work Gabi.   :clap:
  • IA
  • 1993 K1100RS
1973 Honda CL70-K3, 1975 Kawasaki 350 F9-C, 1983 Kawasaki KZ750-K1, 1993 BMW K1100RS, 2008 Suzuki GSX1300-BKK8 #1120
Re: The MechaniK
« Reply #12 on: November 07, 2017, 06:43:37 AM »
The fuel cap. It is not an "aviation type", it is actually a Boeing 707 fuel cap. We are using some aircraft parts on this bike. For example, the uniballs used for the gear box' lever its also Boeing 707 parts.
  • Romania, Europe
Re: The MechaniK
« Reply #13 on: November 07, 2017, 06:44:47 AM »
Thanks for the input
  • Romania, Europe
Re: The MechaniK
« Reply #14 on: November 07, 2017, 07:49:22 AM »
The coolant reservoir. We modified an oil catch tank, as it was laying around :). We will fabricate some aluminum parts in order to fix it. Work in progress for designing it.
  • Romania, Europe
Re: The MechaniK
« Reply #15 on: November 07, 2017, 07:57:01 AM »
BMW has many of us convinced that water infiltrating the fuel tank from around the cap was probable, so a drain pipe was installed in the tank with a pipe inside the tank that has an inlet along the left perimeter of the cap flange and an outlet beneath the tank. I don't see that inlet accommodation being made on your cap assembly. It's a work of industrial art though.  :2thumbup:
Do you think fuel cap drainage is just another example of BMW's unnecessary overbuilding, or have you designed something I haven't noticed?
Re: The MechaniK
« Reply #16 on: November 07, 2017, 08:10:16 AM »
Many thanks for the info. Actually yes, I designed an O-ring between the bmw fuel cell and the adaptor plate. The chances are zero for the water to get inside the tank. I also left some space between the fuel cap (inside of it) and the adaptor for the ventilating and anti vacuum purposes. I really didn't want any screws visible, that's why I designed it this way. And it's finished, btw :)
  • Romania, Europe
Offline duckytran
Re: The MechaniK
« Reply #17 on: November 07, 2017, 10:16:34 AM »
Very impressive build Gabi. Lots of cool designs. I'd like to see how your rear suspension will turn out compared to this one.
  • Austin, Texas
  • 1993 K75, 1981 R65
Re: The MechaniK
« Reply #18 on: November 07, 2017, 10:22:48 AM »
Thanks a lot for the nice words. I tested the suspension and it works pretty well. I can't upload a video, maybe I will have time to upload on YouTube or something.
  • Romania, Europe
Re: The MechaniK
« Reply #19 on: November 07, 2017, 10:28:36 AM »
The water tank design is finished. There will be 6 metal parts (aluminum and one iron part). I think will look good :)
  • Romania, Europe
Re: The MechaniK
« Reply #20 on: November 07, 2017, 11:24:26 AM »
. . . Actually yes, I designed an O-ring between the bmw fuel cell and the adaptor plate. . .
Thanks for the explanation.
Re: The MechaniK
« Reply #21 on: November 07, 2017, 11:25:22 AM »
  • Romania, Europe
Offline riots100
Re: The MechaniK
« Reply #22 on: November 07, 2017, 06:56:46 PM »
I like the look of repurposed aircraft parts. :2thumbup:
  • Los Angeles, CA
  • 1992 K75, 2007 K1200GT
Bruce Johnson
Re: The MechaniK
« Reply #23 on: November 14, 2017, 04:56:04 AM »
Starting working on the custom triple clamps. Keeping the bmw trail and rack, including the bearings (of course we will replace it with new ones), but wider, in order to use the 6 pistons calipers and 320 mm disc brakes. Using Suzuki gsx-r shocks.
  • Romania, Europe
Re: The MechaniK
« Reply #24 on: November 14, 2017, 05:06:33 AM »
Under construction
  • Romania, Europe
