I got one 46-63-7-686-746 and one ...569 from the link supplied by Gryphon. The 569 is a bit more 3D, but there are small air bubbles under the top clear layer. The 746 has a thin foam adhesive backing, the 569 has no foam, just adhesive. Time will tell which lasts longer.
I cleaned off the old adhesive with alcohol, scuffed the surface with 220 grit, and cleaned with alcohol again. Looks good.
Thank you all!
